Home Forums Products Stompboxes H9 Decay of reverb (Hall) is changed by tap tempo when the tempo is OFF in the preset Reply To: H9 Decay of reverb (Hall) is changed by tap tempo when the tempo is OFF in the preset
#127346
For the moment I have a temporary solution for this.
The H9 (A) that I use for tap tempo is used for delays and the other H9 (B) is used for reverb and ambient.
If I tap tempo on A now with the switch of the H9 itself or via an external aux switch, it changes the tempo of delay and other tempo ON patches. The decay of the reverb on B is not changed when tempo is OFF in that case. It ignores the incoming midi clock so to say.
If I select a reverb (with tempo OFF) on A and use the tap tempo switch on the H9 itself or AUX it changes the decay of the reverb.
– A has CLK.OUT ON
– B has CLK.IN ON.
– A has MIDI OUTPUT to XMT
– B has MIDI OUTPUT to THRU
BTW, I still use an expression pedal combined with 1 AUX switch together (Y cable) succesfully where the switch is used for tap tempo. Tap tempo is set to FS3 and the EXPTIP is set to both.
