Home Forums Products Stompboxes H9 Distortion presets? Reply To: H9 Distortion presets?
#127350
jamongrande
    As mentioned, Octaver allows for a semi-variable fuzz, as does the Harpeggiator algorithm. They are real nasty, reminding me of some of the Downward Spiral era NIN sounds.
    You can also use the Bias Trem to create a somewhat gnarly overdrive by cranking up the gain/mix knob; you may want to reduce the overall output as well. It works alright running into a driven amp, or as an unusual texture.
    Joe
