Home Forums Products Stompboxes How to send MIDI CC from H9 Exp Pedal to Space? Reply To: How to send MIDI CC from H9 Exp Pedal to Space?
#127354
gkellum
    When you say that you have an expression pedal hooked up to the H9, is it a MIDI or an analog expression pedal?  If it's analog the H9 won't convert that to MIDI for you, but you can use a cable splitter to connect the same expression pedal to Space…
