Reply To: H8000FW AES/EBU clocking issues
Home Forums Products Rackmount H8000FW AES/EBU clocking issues Reply To: H8000FW AES/EBU clocking issues
#127381
You don't say which AES you are using on the H8000FW, but I'm going to guess that it is one of the back panel XLRs. This is because there is a difference here from our other rack units, as these cannot be used as sync sources. (see User Manual p.10).
I would suggest that you either use one of AES11-17, or WordClock as the sync source for the H8000FW.
