Home Forums Products Rackmount H8000FW AES/EBU clocking issues Reply To: H8000FW AES/EBU clocking issues
#127382
homer
    Hi Nick,
    thanks for the answer. Sometimes I would appreciate if you would dedicate a paragraph in the manuals to all the things that are different or special on the particular unit. 🙂
    Sad to see that you changed that on the unit. I mean I wanted to keep things consistent such that clock is distibuted over AES/EBU only as I have a BURL ADC that is in the loop, too. In that case I would need to shell out 100 bugs for that DB25 snake…not. May be it is easier to slave the H8000 to the Orville via SPDIF…I' will try that and get back to you in case I need some more help.
    Thx anyway
    John
