Home Forums Products Stompboxes Expression pedal control of multiple H9s Reply To: Expression pedal control of multiple H9s
#127457
KCStratman
    "H9 A & H9 B = Set the XMT CHannel and RCV CHannel to same number [1-16 pick one]
    H9 A Output Mode = Transmit [XMT].  H9 B Output Mode = THRU.
    H9A XMT CC = PED > CC 15 (arbitrary).  H9 B RCV CTL = PED > CC 15 (match to XMT)"
    Yes, thanks those are exactly the settings I tried, as well as the General settings and Midi settings in H9 Control menu. I will experiment more with synching up via midi but the fact that you can't visually confirm anything in H9 Control while midi-ing kills it for me. I guess a Y cable to two units will do.
