Home Forums Products Stompboxes Anyone using the Roland EV-5? Reply To: Anyone using the Roland EV-5?
#127462
    Of course, the side trim pot needs to go all the way towards toe (0 setting).  I'm sure you've already tried that, but it's easy to accidently nudge it back.  I used to have that problem with my EV-5 and the PitchFactor.  I'd unplug it, then plug it back in, and re-calibrate it.  That seemed to work most of the time.  Occasionally, I'd need to cycle the power with it unplugged first.
    I use that same EV-5 now into an EHX 8 Step Program, then out to my PitchFactor / H9.  After initial calibration, I set Pedal -> Pedal Calibration Disabled to YES in H9 Control.  I haven't had a problem since.  I'm not a big fan of the Pedal Lock setting (unless it's needed for a specific circumstance).  I haven't found the need to keep Pedal Lock engaged for the EV-5 as a permanent setting.
