Home Forums Products Stompboxes Option to up/down presets with the H9 footswitches Reply To: Option to up/down presets with the H9 footswitches
#127558
LA Keys
    From the manual, p.:7
    "The Right Footswitch is used to step up or down through the Presets or to tap tempo. Press and hold the Right Footswitch to toggle between these two functions. The Tap LED indicates the current function – Preset cueing: Tap LED OFF, Tap: Tap LED ON.
    Using the Right Footswitch to Cue Presets
    With the Tap LED OFF, press the Right Footswitch to step up (increment) or step down (decrement) through the Presets. The direction is changed by pressing the Knob. The display will show the Preset Number and the first 4 characters of the Preset Name [##.XXXX]. When a Preset is cued the Preset number flashes. Pressing the Left Footswitch loads the cued Preset and makes it Active.
    Hope this help!
    LA
