Reply To: Changing Key In Real Time Using My PitchFactor
Home Forums Products Stompboxes Changing Key In Real Time Using My PitchFactor Reply To: Changing Key In Real Time Using My PitchFactor
#127611
Quote:
The only way that I know to play this part correctly is to change the Diatonic effect "key" several times during the song; that is, change the "key" as the song moves through the I, V, II, etc. changes  …  What is the best way to change the "key" in real time?
In my opinion, MIDI.  If it's only 2 keys + 2 scales, you might get away with using Aux switches.  While I always have expression pedal programming on all of my presets, I personally wouldn't use that to change Diatonic scales.
For an explanation of how I change Diatonic key & scale over MIDI, click here.
