Home › Forums › Products › Stompboxes › Problem with Modfactor MIID Program Changes › Reply To: Problem with Modfactor MIID Program Changes
March 11, 2015 at 2:05 am
#127619
If a preset is saved with the preset in bypass, then when you call it up with a MIDI program change, it will load bypassed. I'm guessing this is what happened. Try resaving the preset in active and see if the problem goes away.
