Home Forums Products Stompboxes TimeFactor problem. Reply To: TimeFactor problem.
#127636
    The 62/63 issue is because the actual value is between the two (maybe 62 and a half), and it may have a little wobble (white noise), meaning it does not know how to display it. If it worries you, tweak the value the tiniest bit in either direction, and it will settle down.
    As for the feedback, don't know. What is on the display while this is happening ?
