Home Forums Products Plug-Ins UltraChannel 64bit VST not found in Sonar Reply To: UltraChannel 64bit VST not found in Sonar
#127765
DGillespie
    Hi joyof60,
    Try just remove the 32 bit plug-in entirely.  If it's loading in 64 bit Sonar, it will be through a bridge which tend to be trouble.  The 64 bit plug-in should work, and is the one you want to use.  If it's not scanning, it might be because the 32 bit one is.
    Dan
