Home Forums Products Plug-Ins Need preset 533 Voice Doubler for Digidesign Venue Reply To: Need preset 533 Voice Doubler for Digidesign Venue
#127825
Posted by DRooney
Hi Sully,
No not at this time. However let me offer this until Dan can offer a formal answer, which may actually turn out to be similar.
Pull up the Factory plug and select the “Doubler” preset. Then to create a sweeping effect on the pitch take the output of one LFO and attach it to the pitch mod inputs of both pitch shifters set the lfo for a sine wave around 1 Hz(you can get the actual LFO info from the eclipse preset), and set the pitch mod amount parameters in the pitch shifters to around +15 cents and -15 cents accordingly (you can get the actual number from the H3000 preset). When you do this take the other pitch shift amount off, set it to 0.
See if this does anything for you.
Best!
D. Rooney
