Home › Forums › Products › Stompboxes › Momentary “infinite repeat” switch › Reply To: Momentary “infinite repeat” switch
#127959
DGillespie
    Hi Alex,
    This is already possible using the aux switch input. You can assign aux switches to any parameter change just like the expression pedal. All you need to do is assign the up position to no feedback(or whatever you want) and the down position to 100% feedback. The setup is in the system mode and the exact steps should be in the manual.
    Dan
