Home Forums Products Rackmount Eclipse V3.5B4 posted Reply To: Eclipse V3.5B4 posted
#128037
Cleared setup and still have the same problem. Its flakey. Sometimes its ok other times its not. Output levels are jumping up randomly also.
Another issue (i think) Assigning external controllers to FXA & FXB bypass seems to not work correctly with my ground control instant access midi cc's. Yes the Eclipse "sees" the CC, however it requires 2 cc messages (ie 2 button presses on the ground control) each time to bypass or switch on. I do not have this problem with the main bypass, and tap tempo assignments. Perhaps the FX block bypass needs to accepts "momentary" type commands ??
cheers
