Home › Forums › Products › Rackmount › Eclipse V3.5B4 posted › Reply To: Eclipse V3.5B4 posted
#128044
Hi
I understand you'd like to have the pedalboard LED reflecting the bypass status. We'll look into it and see if it is possible.
 Can you use the preset FX a/B MIX parameter?Every p?reset has a MIX parameter for dry/wet balance, available separately for each FX Block. Their settings are stored within the single preset.
all the best
I
P.S. we need your unit serial number , as requested in my previous email! Thanks
