Home Forums Products Rackmount rolling your own algorithms: how does it work etc. ? Reply To: rolling your own algorithms: how does it work etc. ?
#128076
IDeangelis
 Tim
this is a monster!
Re the integration w/DAW software, the unit has drivers for the Firewire connection.
Be aware there are some limitations with Fw drivers in these softwares. Some allow drivers aggregation (audio interface + H8000FW) like Logic and ProTools, others don't.
You can obviously use the unit via ADAT/AES-EBU/Analog/S.Pdif.
You can build a 50 ch mixer!
You can do all you described. yes there is more horsepower than that. The 2 DSPs can also automatically switch to Monolithic Mode to run a single HUGE algorithm if it doesn't fit in a single dsp.
You can create any feedback path you want, both inside the algorithm and the unit I/Os…. with care!
That's all you need to do?
Big Smile
