Home Forums Products Rackmount rolling your own algorithms: how does it work etc. ? Reply To: rolling your own algorithms: how does it work etc. ?
#128085
 Hi again Tim!
It's possible to create a keyboard playable software.
Pitch shifting can't be controlled via MIDI notes as you would like it to be, at the moment.
The unit always has 8 I/O from/to the outside world. The 8 inputs can be connected to both DSPs inputs for 8 channel parallel routing. The 8 outputs of both DSPs can be summed at the 8 physical outputs.
Control is more than sufficiently faster for all tasks. Audio to Control and Control to Audio modules are also available to add more smoothness if needed.
cheers
