Home › Forums › Products › Rackmount › Using Eclipse with minimixer to turn it into parallel loop › Reply To: Using Eclipse with minimixer to turn it into parallel loop
March 17, 2008 at 12:52 pm
#128269
Hi Scott
the basic condition to set up a parallel setup is to run a dry channel between the loop and the mixer + 2 wet channels from Eclipse. Using the Kill_Dry function in your mixer, I suppose you would have the ability to mute the dry channel in your mixer.
Regarding Eclipse, you can set wet/dry balance inside a single patch. Keep the system wet/dry on 100% wet for pure parallel settings. When a "serial" one is needed, just change the wet/dry balance inside the PARAMETERS area of the single preset and store it.
Is that what you wanted to know?
I
