Home Forums Products Rackmount Using Eclipse with minimixer to turn it into parallel loop Reply To: Using Eclipse with minimixer to turn it into parallel loop
#128270
Thanks Italo!
I guess I shoudl ask you for advice on the best way to run the Eclipse in mono. I used to do wet/dry/set and that was amazing. Then I did wet/wet and that was great too. Now I am lazy and just want to bring the amp head, rack, and 1 cab. LOL
So, I understand I need to input in mono to the Eclipse and return both of the Eclipse outputs to a mixer. Correct? Is there some way to set the Eclipse as just a mono device for delay and verb? Would I sum the L/R in the mixer? Or as I saw you post, just return one side? If so, why use a mixer?
Thanks!!
