Home › Forums › Products › Stompboxes › expression pedal with tap tempo › Reply To: expression pedal with tap tempo
April 14, 2008 at 9:38 pm
#128489
The expression pedal on the timefactor does not work like the Line6
pedal at all (thankfully). In the Line6 DL4, the expression pedal
morphs between two preset settings, whereas the Timefactor works like a
conventional expression pedal should (i.e. varying a single, or
multiple parameters within a single preset).
That
said, if you do not change the delay time knob(s) while assigning the
expression pedal, you will have a constant tap-tempo for both heel
up/down.
Cheers
Kris
