Home Forums Products Vsig and Preset Development SuperModule IO Reply To: SuperModule IO
#128517
Not much…but if you combine several supermodules in a sigfile..and it's getting a big one….these modules may take some dsp cycles needed by other resources. Sometimes an algorithm may be "on the edge" and little adjustments may help it loading & running.
Everything depends on size and resources here, so you may remember to remove unecessary modules if needed.
