Home › Forums › Products › Stompboxes › Timefactor bypass via midi footswitch? › Reply To: Timefactor bypass via midi footswitch?
April 24, 2008 at 5:04 pm
#128569
You need to go to the System Menu then Midi then Rcv Ctl then turn the Encoder until you see BYP > -(or some number). Press the right footswitch, then turn until you've selected the correct CC number. Or you could use the learn function and press the right footswitch again and pressing the relevent button on your Midi controller.
