Home Forums Products Stompboxes Tap Tempo aux switch issue/question Reply To: Tap Tempo aux switch issue/question
#128616
     Good !!
    A point worth adding to our knowledge base is that one should use a stereo (TRS) jack into the AUX input. If one uses a mono (tip and sleeve only) jack, the unit will view it as a TRS jack with ring and sleeve connected. If then a switch is connected between T and S, it will be viewed as making T+R, which may be unexpected.
