Home › Forums › Products › Rackmount › Eclipse V3.5 Block bypass externals – problems › Reply To: Eclipse V3.5 Block bypass externals – problems
June 16, 2008 at 9:28 am
#128733
Hi, The Ground Control does not allow you to change the value of a CC only the actual CC change. Interestingly Never had a this problem with the Eclipse Global bypass.
