Home › Forums › Products › Stompboxes › Updater crashes :-( › Reply To: Updater crashes :-(
July 17, 2008 at 12:25 am
#128824
I was having the same problem…the utility kept getting stuck b/c my PC wasn't properly recognizing the Timefactor. I had to disconnect and reconnect the USB cable and select "No, not this time" then the "detect automatically" option twice. Windows then recoginzed the Timefactor. After that I launched the utility again and everything worked just fine. Hope that helps someone.
