Home Forums Products Rackmount Problem installing H8000FW drivers on WinXP Reply To: Problem installing H8000FW drivers on WinXP
#128837
splitrmx
    Unfortunately none of the above worked. I even ended up reinstalling Windows and then trying the driver from the CD before installing anything else and I still get the same problem. I'm thinking it may be some hardware fault with the firewire card in the PC (perhaps the Eventide is trying to use more bandwidth on it than its used to!), I'm going to buy a new card and give it another whirl. Thanks for all the suggestions so far!
