Home Forums Products Stompboxes Modfactor MIDI-control issues Reply To: Modfactor MIDI-control issues
#128839
rjohns1
    I am having MAJOR problems with midi control of both my timefactor, and modfactor, particually with controlling the expression pedal setting with midi. The device does not even see the CC signal, or doesn't recognize it. I know that my FCB1010 works, however, I can control every aspect of my digitech whammy with no problem, and the signal chain of the midi is as follows:
    FCB1010>>>Modfactor>>>Timefactor>>>Whammy
    Whammy is midi channel 1, Modfactor is midi channel 2, and Timefactor is midi channel 3. I can change presets fine, but just can't control the exp. settings. I have tried several values for the CC number, none work.
    Thanks for the help in advance!
