Home Forums Products Rackmount Help upgrading my Eclipse… Reply To: Help upgrading my Eclipse…
#128862
Rusty
     Hi Italo,
    >> let's check if your bootloader is working correctly or if it needs updates.
    Sounds good.
    >> Remove the card from Eclipse and try powering it while pressing the 1 key.
    I have removed the card, and holding down the 1 key on power up:
    (1 beep)
    Loading Operating System
    Powering on 1.200
    Loading Processing Code
    Initialising
    Loading Program
    >> Try againg with the 2 key.
    I have removed the card, and holding down the 2 key on power up:
    (1 beep)
    Powering on 1.200
    Initialising
     Loading Program
    >> In both cases the unit should boot into different update modes. Please report the unit behaviour on these
    tests.
    As above, plus I have removed the card, and holding down the 3 key on power up:
    Doesn't seem to be any difference?
    Regards,
    Rusty
