Home Forums Products Stompboxes Problem with expression pedal Reply To: Problem with expression pedal
#128867
     25K will be fine.
    The taper issue is difficult, and as pointed out earlier, something of a personal choice.
    It also depends what aspect of the pedal you are mainly controlling – for example, volume probably wants a logarithmic taper,  while some other functions will work better with a linear taper.
    A pedal sold as a volume pedal will probably have a log taper, whereas a controller pedal may have a linear taper.
