Home › Forums › Products › Rackmount › Modfilter Distorting › Reply To: Modfilter Distorting
August 18, 2008 at 7:55 am
#128908
Tom
please do the following, as requested:
-keep your LED monitoring at input stage and report how many LEDs light up.
-try other sampling frequencies as a test. I haven't said you should use others. The test is important to us.
I would also try other source materials and check if you get the same problem.
Thank you
I
