Home › Forums › Products › Stompboxes › Timefactor Tap dysfunction? › Reply To: Timefactor Tap dysfunction?
#128945
 Are you in Tap Tempo mode?(that's what digital kettle was getting at)  If not, then using the tap switch will sync both times to the tap – rememberign the interval would be impossible, since you would have to tell it what the interval was relative to i.e. bpm). However, if you're in tap-tempo mode, then if one delay is set say for an eighth, and the other for a quarter note, then tapping will not lose the structure of the delay, but will only change the bpm. Does that make any sense?
