Home › Forums › Products › Stompboxes › Timefactor Tap dysfunction? › Reply To: Timefactor Tap dysfunction?
#128951
mak
    OK- no I wasn't in tempo mode-and yes the echoes are preserved this way. I was just pressing the bank select sw/- until xxx-bpm came up-which then puts both delays to the new tap time.So- each time you change banks- you lose the tempo selection, so you have to press down on the knob to re- engage it-and then access Tap via the Bank button and retain global tempo??
    Thanks for your time
    MK
