Home › Forums › Products › Stompboxes › Powered-up TimeFactor not remembering Aux Switch settings since update › Reply To: Powered-up TimeFactor not remembering Aux Switch settings since update
September 4, 2008 at 3:22 pm
#128976
Thank you for the info – yes, I did have my aux switch's T&R applied to both the tap and the loop-stop button. However, I also had the Tip assigned to Loop Play and the Ring assigned to Loop record.
Since double-assigning the T&R pedal is iffy, How do you folks recommend we use the three pedals (both of the Aux switch and the three built-in pedals) for looper control, bank selection, AND bypass/reverse/tap tempo? Is it possible?
Thanks.
Micki
