Home Forums Products Stompboxes Ideas for future Timefactor update Reply To: Ideas for future Timefactor update
#128986
micki001
     Precisely that process with a few more details:
    1) Power up. Aux Sw does not function as desired, so…
    2) on Utility/Aux Sw page, observe tap switch is already set to AUX T+R (as well as Looper Stop) as desired, despite the non-functioningseen in step 1.
    3a.) Tap Aux switch to un-assign to TAP
    3b). Tap Aux switch again to re-assign to TAP
    3c). Switch works as desired, even after changing patches and banks
    4) Power down
    5) Power up – setting is ostensibly saved and is visible as in step 2, but the switch has no effect until un-assigned and re-assigned.
    In short, if an Aux Switch is assigned to two destinations (for example, Tap and Looper Stop), after restarting the box, one of the assignments is lost. I posted about it in the other 'hot' thread on the forums:
     http://forum.eventide.com/cs/forums/t/4995.aspx
    Thank you for any and all help you can provide… if the FS1/2/3 assignments serve this purpose I'll be okay – but the behavior above is a little hinky.
