Home › Forums › Products › Vsig and Preset Development › Monolithic question › Reply To: Monolithic question
January 15, 2009 at 2:50 pm
#129277
As your manual tells you, under SERVICE you'll find the CLEAR SETUP function. This brings the unit back to factory defults without erasing your presets.
Or you can try a full reinitialization by pressing and holding the 8 key at power on. You may want to wait until you see 4000 in the display to press the 8 key.
This function will erase your presets.
Whatever procedure you will use, it's always a good thing to backup your presets before!
best
I
