Home › Forums › Products › Rackmount › Question about routing vocals with H8000FW › Reply To: Question about routing vocals with H8000FW
#129384
akjl4
    Yes, I currently have my mic going into analog input 1 and the H8000 is setup in the firewire a>b routing scheme. Then I get audio into logic fine like this but, the eventide processors are processing the audio before it reaches logic. I would like to keep it dry (bypass the processors on the way in) and add some plugins then route the audio back using logic i/o plugin and the eventides firewire in/outs. But you see as of now effects are applied to the vocals before even reaching logic and then again when I add the i/o plug and the firewire i/o. Can I get the vocals to logic, add plugins and then use the i/o plugin while monitoring the fx? I have achieve all but bypassing the processors the first time the audio reaches logic.
    Thanks,
    Alvin
