Home Forums Products Rackmount Question about routing vocals with H8000FW Reply To: Question about routing vocals with H8000FW
#129394
akjl4
IDeangelis:
You don't need anything to slit a signal fed to the Eventide. Infact its internal routing allows you to route any input to any or all DSPs inputs as you like.
best
I
Ive been attempting to do this routing to no avail, miv>pre>analog 1 input and am trying to send that same signal to four main inputs so quadrupling the same input so I can make use of the multichannel effects, any advice on how to do this? Yesterday I tried changing firewire inputs 1-4 to analog 1-4 but that did not work. Keep in mind the only way I can connect to my computer right now is through firewire, thats why I thought I might need a mixer or something, was not sure if I could do the routing I need while using the firewire connectivity.
