Home › Forums › Products › Stompboxes › Unclean the ‘factors? › Reply To: Unclean the ‘factors?
#129442
I haven't tried a EPpre but I have a real echoplex and with the preamp after the 'factor it adds a little compression and warmth. The other thing you can do is run the 'factor in front of the amp instead of in the effects loop. I found the digital delays just too clean to be used in the loop.
