Home Forums Products Stompboxes PLAY MODE PROGRAMMING QUESTION/HELP Reply To: PLAY MODE PROGRAMMING QUESTION/HELP
#129456
     Uh huh. Getting more complicated now.
    The new PitchFactor will remember the settings for each effect, but they will be lost at power-down – it remembers only the current effect through a power cycle.
    This may not work well on MF or TF with earlier versions of the software – sadly, I cannot be more specific as this is not a documented feature.
    So, you could try it out and see if it works well enough for you.
    Better yet, study the presets, and set it up so you have what you want without it causing headaches.
