Home Forums Products Stompboxes Timefactor bypass via midi footswitch? Reply To: Timefactor bypass via midi footswitch?
#129549
Not sure that there is an issue here to resolve.
Currently you can take TF either in or out of bypass with a single CC message.
The PF is a newer product which also allows bypass to be selected by a Program Change message, allowing more control by less sophisticated pedalboards.This capability will be available in a future upgrade for TF and MF.
In contrast, the Rocktron is a very flexible unit which should allow you to do almost anything.
