Home › Forums › Products › Stompboxes › Timefactor bypass via midi footswitch? › Reply To: Timefactor bypass via midi footswitch?
March 28, 2009 at 2:49 pm
#129573
In a future update, could you make it possible to reverse the way the controller works, ie making value 127 (or 64-127) disable bypassand value 0 (or 0-63) disable it. It would help controlling the TF with a MIDI controller using fixed CC values, such as the VoodooLab Ground Controll Pro (in which, unlike Rocktron AA, can't specify custom values for instant access switches).Or can it be done using the Learn function ?
