Home Forums Products Stompboxes Trouble setting up TF to control MF Reply To: Trouble setting up TF to control MF
#129701
achaput
    You might have to set up the MF via Receive Map if the factory settings have been changed. The slave pedal's RCV CH (MIDI receive channel) should either OMNI or match the controller pedal's XMT CH (MIDI transmit channel.)
