Reply To: Stompbox Routing
Home Forums Products Stompboxes Stompbox Routing Reply To: Stompbox Routing
#129738
Roodyrocker
Thanks for the info Alan. I realize there is no wrong way to do it but figured I'd ask since I've seen the recommendation for placing the Picthfactor after the OCD elsewhere as well. I thought that was interesting since with older pedals such as the Boss HR2 they always recommended feeding it the cleanest signal first. The problem I ran into with the old Boss HR2 is that it simply sounded too garbled live and I removed it from my pedal board. BTW, it was nice meeting you at the last couple Winter NAMM shows. I was the guy that said from the begining that Eventide should release a Harmonizer in pedal form as its what you're known for 🙂 Anyway, i will try the PF before and after the OCD and see what happens.
Thanks.
Rudy
