Home Forums Products Stompboxes Stompbox Routing Reply To: Stompbox Routing
#129739
achaput
    badmelonfarmer:
    Last time I asked the question about the order of the evetide stomps, I was recomended trying :-
    PF>TF>MF
    is this because I was putting the factors in the FX loop, or all just personal taste?
    Hi badmelonfarmer,
    The suggestion I made above had to do with placement of the distortion source before PitchFactor instead of after. As far as the three Eventide pedals, PF>TF>MF is a fine way to connect them. It will result in some very trippy sounds due to TF's echoes being modulated by MF.  Also as I said there is no 'wrong' way. The best thing to do is try different things and see which way you like the best.
    Alan
