Home › Forums › Products › Vsig and Preset Development › Patch problem › Reply To: Patch problem
July 7, 2009 at 3:08 pm
#129888
It's wrong to use a MIXER. A MIX should be used.
Your previous (and current design) has 4 signals (2 inputs + 2 pitch shifters) feeding back into a single input (MULTISHIFT); that's too much. With hi levels in the MIXER channels you saturate the audio and kill the signal.
You should not use a multishift w/ a mixer. A true stereo path should be used instead, using 2 separate single voice multishifters ot 2 pitch shifter modules.
Check my fix!
I
