Home Forums Products Vsig and Preset Development Patch problem Reply To: Patch problem
#129889
Thanks,
It seems that the point is to keep the signals from the pitchshifters separate otherwise they become very sensitive to overloading of levels (and they go quiet).
Are there other modules that are critical in the same way? (e.g I would suppose the reverbmodules are not…)
Finally, are there any "rules" when you should use the PercentageKnob instead of the usual Knob? E.g it seems sensible to use the PercentageKnob with the Mix-module, but when I tried it on the Mixer-module I got a different response (and actually an error)..
Also, I am quite impressed with Vsigfile 2.4.9  when I have started to work with it.
Razo
