Home Forums Products Stompboxes Killdry Changes via a Preset or MIDI Reply To: Killdry Changes via a Preset or MIDI
#129959
achaput
    OK I understand now. Currently you can store presets at 100% wet, 50% wet etc, but you also want to be able to use PitchFactor as a volume pedal when it's 100% wet.
    Yes unfortunately Killdry is a global parameter but I will add to the feature requests the ability to make Killdry 'per preset.'
    in the meantime, are you using a mono setup? If so then you could try to take advantage of the fact that when stereo outputs are plugged in, Voice A goes to Output1 and Voice B goes to Ouput2. This means you could use the Pitch Mix knob as a volume control for Voice A on Output1 as you long as you have something plugged into both outputs. Just a thought…
    Alan
