Home › Forums › Products › Stompboxes › Killdry Changes via a Preset or MIDI › Reply To: Killdry Changes via a Preset or MIDI
July 28, 2009 at 7:29 pm
#129960
Bingo you got it…. Thanks…. Regarding using the two inputs. I did try that, problem is that when I use both inputs the Crystals patch becomes only half of the sounds. It sounds very odd if I only use input 2 and output 2 and the input 1 has nothing coming into the PitchFactor. I was hoping that would work for me.
