Home › Forums › Products › Stompboxes › TIME FACTOR MIDY BYPASS WITH PROGRAM CHANGE › Reply To: TIME FACTOR MIDY BYPASS WITH PROGRAM CHANGE
August 3, 2009 at 8:56 pm
#130001
Have you considered using Aux Switches?….It appears that Toggle Bypass/Active is controllable via these switches…….or, perhaps upgrade to a more comprehensive MIDI Controller.
As a keyboardist, my instruments handle all the MIDI implementation, but I can see you may need to upgrade…good luck!
